hey
servo as in active servo by yamaha?
thats just stupid hype words used to make ya think they're stuff is better
you need a plate amp
and a subwoofer
if you want something that virtually unbuyable in value and performance,
build a powered 12" shiva with a 250 watt parts express plate amp
www.adireaudio.com
www.partsexpress.com
good luck
and a subwoofer
www.adireaudio.com
good luck
You can go with Rythmik Audio...
http://www.rythmikaudio.com/servo_product.htm
They sell a complete kit.
The new woofer for DirectServo kits is made by AE Speakers. I can personally speak to the quality of AE Speakers woofers and their impeccable attention to aesthetics as well. The dark gray anodized single-piece aluminum cone makes for an extremely nice-looking driver.
Addendum
I think that the Rhythmik kit is the best one for you because you can have the satisfaction of DIY but the performance of a servo subwoofer. This is not an accelerometer based servo system and has good stability. This will being you closer to true accelerometer servo perfomance (which is what you may be accustomed to) than even a critical Q box. The price of admission is higher than a typical sealed-box or vented-box sub but then again, it does have a specially-designed servo circuit. Just knock together one of their recommended sealed enclosures (for an EQ'd driver I recommend the larger sealed box option) and start enjoying servo bass. For just under $400 for the driver/amp kit, reviewer Ralph Calabria calls this kit a bargain. It seems a lot for a sub kit but remember that there is a complex custom-designed servo feedback circuit in the plate amp that had to also be designed by Rythmik; these aren't just off-the-shelf components.
More Blah, Blah, Blah...
Read this article to see just how the DirectServo principle compares to accelerometer servo technique in the interview section at the bottom of this article. http://www.hometheaterhifi.com/volume_11_2/diy-14-rythmik-directservo-subwoofer-4-2004.html
I have two of the Rythmiks. One for HT , one for music only. High performance/price ratio IHMO. Definately a step up from the plethora of basic sub+amp kits out there. Can't comment on the brand new drive unit as I have the previous drivers.
Cheers
AJ
Cheers
AJ
BAM said:The new woofer for DirectServo kits is made by AE Speakers. I can personally speak to the quality of AE Speakers woofers and their impeccable attention to aesthetics as well. The dark gray anodized single-piece aluminum cone makes for an extremely nice-looking driver.
I thought they were made by TC Sounds. Which would explain the TC portion of their driver's name. Definately parts sourced from TC sounds I am thinking. Not trying to take anything away from John at AE here (he is awesome), but I just don't think he is the one making those drivers. As far as I know, from being a Stryke/AE customer for many years now, John hasn't made a grey-anodized cone driver, let alone one that didn't have a dustcap or phase-plug of some sorts. Where did you get the info that John was making the drivers for Rythmik may I ask? Just curious is all...
Noidster
John used TCsounds to manufacture drivers for him, I don't know if it's the case here. John no longer use TCsounds. He does it all by himself now.
I had a discussion some time back with John about what he was workingon, and he said he was pursuing some possible production contracts with Rythmik Audio and ACI. I saw the new Rhythmik woofer and made the leap. In a later conversation with John I learned that the Rythmik guy wanted a certain voice coil length that wouldn't have worked well for his application. then the Rhythmik guy decided he wasn't going to mess with AE and had TC Sound build the woofer. It was kind of a stupid thing, really, since the voice coil length would really have to be what the Rhythmik guy specified so that the motion sensing coil would interact properly with the magnetic gap for limiting functions, whichwas a bad move on John's part
BAM said:I had a discussion some time back with John about what he was workingon, and he said he was pursuing some possible production contracts with Rythmik Audio and ACI. I saw the new Rhythmik woofer and made the leap. In a later conversation with John I learned that the Rythmik guy wanted a certain voice coil length that wouldn't have worked well for his application. then the Rhythmik guy decided he wasn't going to mess with AE and had TC Sound build the woofer. It was kind of a stupid thing, really, since the voice coil length would really have to be what the Rhythmik guy specified so that the motion sensing coil would interact properly with the magnetic gap for limiting functions, whichwas a bad move on John's part
Interesting indeed. Probably something John didn't really want to take on right now anyhow as he is so busy with his own drivers and biz. I will have to ask him later this evening and get the low-down maybe.
Noidster
Servo drivers
Hi all,
Just to clarify, the new driver R12TC is indeed made by TC sounds. I did plan to source from AE. However, John cannot make them as soon as I had wished. And I had a list of customers waiting for the new drivers.....
Regardless of who makes the driver, I would like to assure you that the new driver is just as musical as the previous version (even though I actually pay more for them). The key features to make the direct servo kit sound so wonderful is really the servo technology, direct coupling of servo feedback signal, tight magnetic gap, low moving mass, and effective short circuit ring. The servo technology reduces the memory effect from the spider/surround and thermal memory from the voice coil. That is why our servo kits sound so articulate.
Please do not confuse our servo kits with those in Yamaha. They don't even have sensors in their drivers. So how did they get the servo signal? They use current feedback and market that as servo.
Brian D.
Rythmik Audio
Hi all,
Brian D.
Rythmik Audio
I still like idea of a woofer with .5 hd at 114 db. The martin logan servo is what Iwant to try to build.
I am not familiar with ML's servo sub, but our servo sub does have multiple damping settings. The high damping setting is Q=0.5. In addition, we have mid damping with Q=0.7, low damping with Q=0.9, and all of these can be set with a toggle switch on the plate amp. The user can adjust it according to the play back material or personal preference.
It is not clear at what frequency the 114db output is rated. But let us do a simple math. A 1.1" p-p excursion on a sealed 12" driver will give us 101db at 20hz. To get 114db at 20hz, it will need at least 1.1"x4=4.4" p-p excursion. However, if it is rated at a higher frequency, our servo subs can also achieve similar performance. For instance, at 40hz, our servo kit can get more than 1.0" p-p excursion which is more than 112db, and above 40hz, the output can go as high as 114db. So achieving 114db may not be not difficult, if no frequency is specified.
I do not claim our servo subs are the ultimate subs or have the highest outputs. But among all the subs that serve dual purposes (music/HT), our servo subs are pretty competitive if we digest the numbers a little bit.
Brian D.
Rythmik Audio
Brian D.
Rythmik Audio
I was talking about your sub the ml play at120 db at 25 hz with .05 hd. I was speaking in general about servo subs in general. they all seem to have low hd
fcotton said:... the ml play at120 db at 25 hz with .05 hd...
Please tell me what model "ml" and where you got these numbers from. Just interested is all...
Noidster
I would certainly expect Brian's new TC drivers to be a step up in quality. TC has a great reputation. 😀 😀
I think he is refering to the "Contrabass" box made by Basstech. This is the passive-radiator design by Tom Danley using a DC servo-motor.
http://www.servodrive.com/Download_files/Contrabass/ContraBass.pdf
Charles
Charles
- Subwoofers
- Servo sub woofer
