Service manuals for CDM-9pro based machines
I m trying to align an older CD player with a CDM-9pro pickup after replacement. The pickup board of the particular machine I'm working on has no focus or tracking adjustments which means they are automatic but it does have a laser adjustment on the pickup itself. I've searched the internet for a service manual from the folowing models below which have CDM-9pro pickups hoping to find adjustment procedure. If anyone has any of the manuals please share the CDM-9pro laser adjustment procedure. I've measured laser power & got .115 mw using a laser power meter,for reference using the same meter I got .12mw from a properly aligned CDM1MKII & .15mw from a CDM3. Thanks in advance.
Philips CD23
Philips CD23limited
Philips CD23D
Rotel RCD990
PS Audio Lambda II
Audiolab 800CDM
Burmeister 979
EMT 982 Professional
Jardis JD-1
NAIM Audio CD1
Marantz CD23
This brands and models are listed from vasiltech :
AUDIOMECA MEPHISTO Transport CDM-9/44 / CDM-9 Pro
BARCLAY DIGITAL F1 and X-1 CD Transport CDM-9 Pro
Burmester 939, 963 and 969 CDM-9 Pro
DUSON CD100 CS4328-KP CDM-9 Pro
GOLDMUND MIMESIS 36 It's a Transport – SAA7310GP CDM-9 Pro
INKEL (Sherwood) TEMA CD-1 TDA1547 CDM-9 Pro
MERACUS IMAGO It's a Transport – SAA7310GP CDM-9 / CDM-9 Pro
MICROMEGA DUO and DUO.CD2.1 It's a Transport CDM-9 Pro
MICROMEGA TRIO.3CD. It's a Transport CDM-9 Pro
MISSION-Cyrus Discmaster It's a Transport – SAA7310GP CDM-9 Pro
NAIM AUDIO CD1 TDA1541A-S1 (Single / Double Crown) CDM-4/27 / CDM-9 Pro
POLYFUSION AUDIO MODEL 920 It's a Transport CDM-9 Pro
PS AUDIO LAMBDA/LAMBDA TWO It's a Transport – SAA7310GP CDM-9 Pro
RADIANT (ver. 3) CS4328-KP CDM-9 Pro
ROTEL RCD-990 and RHCD10 2 x PCM63P – PMD100 CDM-9 Pro
SUGDEN AU51 PRO and PDT10 It's a Transport CDM-9 Pro
SUGDEN SDT-1SE (SDT-1PRO) TDA1541A-S1 (Single Crown) CDM-9 Pro
T+A CD2000AC MKII TDA1547 (DAC7) – SAA7350 – NPC Filter CDM-9 Pro
T+A CM3000AC It's a Transport – SAA7310GP CDM-9 Pro (CDM-9/60)
T+A CM3000R It's a Transport – SAA7310GP CDM-9 Pro (CDM-9/60)
THETA DATA BASIC II It's a Transport – SAA7310GP CDM-9 Pro
VIMAK DT-1000 It's a Transport CDM-9 Pro
