As above. Looking for a service center in the UK who would be happy to service a couple of Ecler amplifiers I have. They both work fine but since they are getting on a bit I think it would probably be good to have them checked over and serviced (if required)
thanks in advance.
thanks in advance.
Unless there is something definitely wrong, don't waste your money. All that will be done is a visual inspection, any known dry joints/heat issues will be dealt with and any swollen capacitors replaced.
Depending on who you send them to it may be anything from an inspection, £50 to as high as they deem fit.
Ecler Amplifiers @ Commercial Audio Solutions
are an Ecler dealership and should be able to point you in the right direction.
