Hi, Merry Christmass and last week of the year according where you 're living. (Santa, drop me your number please as I was dropped a 5 yo kid gift and eventually think there is a mistake ?!)
I would like to pad down a plateau magnitude raise on the middle of a tweeter magnitude.
A serie resistor (already existing in the filter) at the input of the passive crossover circuit is calling my noob skills for an inductor 0.5 to 1 mH parralel, to make a smooth spl notch in spite of a parallel notch with the tweeter inputs to pad down till 1 to 3 dB
I will adjudt by listening in the listening room that inductor value.
I still have to measure with better precision and better gating - 6 ms window perhaps at 1 meter then listening spot at 2.5 meters centred- the standalone tweeter response above 1500 hz. The filter being two 12 dB nodes in serie to make a sorta 24 db hybrid two nodes passive filter with a car tweeter that needs steep slope because the highish Fs for protection before the second electrical cut-off giving the near acoustical filter. I dunno if my english skills are acurate enough for the description to be understood, appoligizes if so.
I know the added parrallel coil with the serie teeter resistor will add + 90° phase change, rigth ? And a non dangerous for the amp, raise of the impedance in that area ?
Am I correct ? Why btw do we not seen that more often in tweeter filters ? Like if experienced designers prefer more global L-Pad attenuation than correcting the middle range of a tweeter non smoothness, we can by the way more often see with a resistor // caps that raise the ending level with a bigger first R attenuation ?
Any thougth on that, is it an issue to introduce a serie coil on a passive filter ? I ask cause I never seen one in my limted experience for a tweeter which has in serie caps and only // coils from 12 dB and upper slopes.
Many thanks
Many thanks
Sometimes it's possible to guess these things but a simulation could reveal unexpected behaviours. Perhaps you could post a picture of the response shape you are dealing with, and the circuit.
Hello,
Thanks to shimm in.
Not made a whole sim for now as coils of the two serie 12 dB are not individually measured yet (I still have to purchase a DVM that has henri measurement stuffs in it in spite of my basic DVM. Dunno if Arta or else can give Henri measurement related to frequencies ?
What is worrying me in that added coil scenario is a mismatch phase tracking between the medium low pass and the tweeter high pass passband area.
In less technical words, I wonder from an unexperienced point of view as mine if subjectivly there, the EQ shapping can be musicaly better than a phase mismatch the added coil introduce. Because, timing is important for transcient, bass snap, etc. And two serie 12DB slope serie is already 360° phase late already vis à vis of the medium driver ?!
Edit : for sure I could just try and check from a subjective listening test, but would like to know if it is a proper way to tweak, by adding passive stuffs or else with passive designs. Understand : in spite of changing for a better suited tweeter and redisigned filter for it
Thanks to shimm in.
Yes, but I still don't know what your response looks like and what you circuit looks like.What is worrying me in that added coil scenario is a mismatch phase tracking between the medium low pass and the tweeter high pass passband area.
Aha, yes we can discuss the effects and we can also discuss solutions.In less technical words, I wonder from an unexperienced point of view as mine if subjectivly there, the EQ shapping can be musicaly better than a phase mismatch the added coil introduce.
Sure. Resonate with a known capacitor, set against a resistor and sweep the Voltage across it until you find the peak. Calculate the value.Dunno if Arta or else can give Henri measurement related to frequencies ?
