Selection of FET configuration for a 10w Amp
Hello people, how are you?
I (a newbie) need help with a project I'm trying to design for personal use and as a university assignment project. The idea is a to keep it simple using discrete components (can't use Op-Amps or TDAs) and not to do a 50 transistor amp.
I want to design a 10-ish watt amp circuit that is a mix of a Tillman kind of preamp (I did this already but using a BC547 in CE with RE config) with a 10w power amp, but I cant decide which configuration or component to use.
My first idea was to use a single IRF510 and power it with a 50v supply , but then I read that is preferably to use a 2SKXXX family device in a complementary configuration.
I know that i want to select a component that will deliver 10-ish watt or a bit more at 50~60% of the max Pd rating. But after that i can't decide how to select the best config. I want the power stage to be the most clear and transparent possible
So i should go with a IRF (or IRL), 2sKXXX o even a tip201?
Is better to use a class a single mosfet amp design to preserve the signal as original as posible or to use a double device complementary design?
Thanks in advance, and sorry for the newbie way of asking this
