Hi All,
I have got my hands on a pair of KEF Q55 speakers. This is a 3 way system. Both tweeters are blown. I have done a fair amount of research on line and from what I can see, these tweeters are delicate and go quite often. They are concentric mounted in the center of the midrange speaker. The only one I can find is a replacement part from KEF for about $100/pr.
I am wondering if it would be better to replace these with a cabinet mounted tweeter that would be more robust. The tweeters are 4 ohm
Any thoughts?
These are the specs for the KEFQ55:
System type: 2½-way, floor standing
Enclosure type: Reflex
Dimensions (H x W x D): 852 x 207 x 276mm (33.6 x 8.2 x 10.9 inches)
Weight: 13kg (29 lbs)
Nominal impedance: 8 ohms
Power Handling: 150W
Frequency response: 40Hz to 20kHz +/-3.0dB (-6dB at 37Hz)
Sensitivity: 91dB at 1m for 2.83V
Maximum output: 112dB
Finish: Black Ash, Mahogany, Video Grey
System: SP3317
Drive units: B160 Bass unit (SP1395), B160 Uni-Q (SP1449) [NT19 tweeter (SP1446)]
Crossover network: SP2338
Thanks.
Ringwood
Any thoughts?
System: SP3317
Thanks.
Ringwood
KEF NT19 tweeter (SP1446)
Before buying anything different or Chinese you can try... "What to do list":
0. Kef replacement parts (originals drivers usually sell in matching pairs.)
1. Sending it to repair shop
2. Buying it from Kef Classic forums
3. Ebay.
Eventually a different type of driver or upgrade will make you spend more money in a new pair of drivers and different new designed and personalized crossovers. So this is many times the DIY route and might take a long time to have the speakers ready (?!) and tested, if not like a new pair of speakers professionally measured. 😎
SpeakerTalk :: Index
www.homemedialimited.co.uk are official stockists of Hi-Fi related products and accessories from many leading brands.
Loudspeaker Design| Loudspeaker Drive Units| Loudspeaker Measurement, Restoration, Repair Services
Wilmslow Audio Repair and Upgrade Service
Contact Us : RA Technology, Projector mounts and cages
Post your success story for others to learn...
3. Ebay.
Hi. It may not be necessary to replace these tweeters as it is sometimes possible to repair.
I'm no electrician and posess basic DIY soldering skills but repaired mine. It's a little fiddly but if you are going to throw them anyway what harm can it do to try?
I have now posted a video on you tube showing the removal, repair and replacement of these tweeters.
Kef Q Series Tweeter Repair Q15 Q35 Q55 Q65 Q75 Q85 Q95c, Point 1 & 2 - YouTube
Hope this helps.
Hope this helps.
Hope this helps.
I realise this is probably a dead post, but just wanted to confirm that it is indeed possible to repair these tweeters, I have just done so too!
