Hello all,
I would like to know if there would be major performance issues if I pair an RCF ND850 2" driver with an RCF HF94 1.4" horn since I have these equipment available to use at the moment. I am aiming for a frequency range of 2khz-20khz. It will be used in a vehicle so space is limited on the horn sizes I can choose.
ND850 is actually a 1.4" exit driver with an extender to make it a 2" exit. You can just unbolt the adapter and have a perfect match(important) to the horn.
Dude... that's mind blowing are you sure about this? I saw on RCF site there is a 1.4" and 2" model. I would have a look at the drivers and see where the bolts are located.
OMGGGG IT WORKED!!!!! came out super easy THANK YOU SOOOO MUCH saved me some cash. Now I can use 1.4" horns 🙂))))
- Selecting horn for 2" driver
