I am looking for a pentode-triode where half is basically a 12AX7 (similar gm, gain 70-100).
Some nice higher-gm options exist (6AW8A), but low idle current would be preferable here.
Pentode should be high-ish gm, to be used as a CCS at ~8-10mA for another stage's differential amp tail. 6GW8 is overkill 😉
It seems that this should be easy, but I have yet to find one
Hmmm... 6CM8 has promise, but the search continues...
6KT8... really nice curves... slightly high gm...
The ECL86 is said to contain a 12AX7 triode and a (derated) EL84 pentode. GM of the pentode is 10mA/V when operated at 36mA...probably less when operated at the desired 8-10mA.
I like the axiome - more current - better sound !
I prefer You 6LR8 very linear tube for TV - Ia triod - 6-8 ma and Ia pentod - 55-60 ma.
I have apl. with 6LR8 and sound is very nice !
ErikdeBest said:The ECL86 xxxxxxxx.
I tried a tempting design around this, but this tube is now getting rare and NOS expensive. The far cheaper PCL86 with a 14 V heater may be an alternative solution. Not sure of US equiv.
richy
jon_010101 said:I am looking for a pentode-triode where half is basically a 12AX7 (similar gm, gain 70-100).
It seems that this should be easy, but I have yet to find one![]()
Questions:
Do you need 12AX7 gain?
How much headroom is available for the pentode section CCS? If you're direct-coupled( the SE gain stage plate voltage setting this qty).
cheers,
Douglas
Re: Re: Seeking Pentode-Triode with a 12AX7 half...
I see many have recommended tubes that are way too serious for the intended application, but I will keep them in mind for future purposes 😀
Gain of 70-100 with gm<2000 would be ideal, and 150V realistically available for the pentode. Must be 9-pin, reasonable 6.3V or tapped 12.6V filament. (BTW, just replied to your reply in another forum 😉)
Interesting - I will investigate! Friends of the 6AW8 are friends of mine!
Bandersnatch said:
Questions:
Tom Bavis said:How about 6EB8, 6GN8, 6LY8, 6JT8 - all have the same footprint as 6AW8.
The 6LY8 and 6JT8 are on sale for $1 each at these two places :
www.esrcvacuumtubes.com
www.vacuumtubes.net
www.vacuumtubes.net
another triode pentode combi with the same pinout is the 6KR8, available from www.vacuumtubes.net This one spots high transconductance on both units, if memory serves me well about 20mA/V.
Edit: I was wrong: the pentode has 20mA/V (with ~20mA current), the triode achieves about 10mA/V with 15mA current.
Excellent! Thanks!
Looks like we have a winner with 6LY8 - high gm pentode, low gm triode that looks very 12AX7y. If it ends up being funky, switch to 6AW8 is just a few resistors away.
6MV8 same footprint as 6AW8, has Mu 100, gm 4000, 1 Watt, on sale for $1 too. with 2.5 W pentode with Gm 9000
7716 same footprint as 6AW8, has Mu 102, gm 2900 1 Watt $4
with 5W pentode with Gm 10,000
- Tubes / Valves
- Seeking Pentode-Triode with a 12AX7 half...
