hi, I am planning to build up a simple 6V6 PP Power Amp (10W
only PI circuit with a 12AT7 per a channel).
I have a power transformers, of which the secondary tap has
a 125-0-125 120mA tap.
Does it mean that it can provide more than 250V DC
to power tubes?
If not no, can anybody recommend me a hammond pwr for this project?
Thanks.
to power tubes?
Thanks.
zxx123 said:hi, I am planning to build up a simple 6V6 PP Power Amp (10W
to power tubes?
Thanks.
if you don't use the CT (i.e. use bridged diodes), it can provide approximately 250 x 1.414 VDC (if capacitor input)
Using a full-wave bridge rectifier, no connection to tap, you can get about 300V at 90 mA, which should be enough for a push-pull pair of 6V6s.
Tom Bavis said:Using a full-wave bridge rectifier, no connection to tap, you can get about 300V at 90 mA, which should be enough for a push-pull pair of 6V6s.
;Hmm, connecting 0-125 with bridge diode (and capacitor input)
will make 300V at 90ma, right?
read my message again. when I said "no CT", I meant the leads to the bridged diodes are connected to both the 125V.
