Secondary output from Dayton Bluetooth Amps?
Hello again friends,
I was curious if there is a manner to get a secondary line level output from the Dayton bluetooth amp boards?
Dayton Audio KAB-230 2x30W Class D Audio Amplifier Board with Bluetooth 4.0
I would like to convert it to a 2.1 setup and run a Sanwu 3118 mono for a small woofer. So I would need line level output (and then sum) to the Sanwu. I was hoping to power it with one of the other outputs from the battery board.
Dayton Audio KAB-BE 18650 Battery Extension Board for Bluetooth Amplifier Boards
Thanks again to all the EEs that tirelessly help amateurs like myself!
