Please note payment via electronic transfer on collection please.
Price £575
Up for sale is a recently completed project. Using the HiVi isodynamic (ribbon) tweeters and Seas Er18rnx prestige 6.5" bass drivers. Crossovers use high quality capacitors and air core inductors. Based loosely on the Zaph SR71 and Starling designs. If you are familiar with the rather well regarded Kudos range of loudspeakers their X3 floor stander uses the same Seas mid bass driver in a similar ported enclosure. This digs pretty deep yet manages a really detailed mid range clarity. Great for vocals and complex bass lines.
CNC machined metal feet each about 7kg with grub screws at the back so you can adjust the angle the speakers incline. Designed for a listening position of approximately 2m ~ 2.5m and elevation of 1m.
Cabinets are painted Valchromat and white melamine faced plywood baffles, assembled and professionally finished. Cabinets are ported and produce prodigious amounts of bass. If you like ribbon tweeters you will probably like the balance of detail and resolution these give without being too analytical.
21cm wide
18cm deep
76cm high
More than the sum of its parts and near double the cost to make as I'm asking. Too many projects mean these have to go. Ideal basis for those that like to experiment complete with a high end finish.
Collected from Oxfordshire
Alternatively postage within the UK by Parcelforce 48 is about £60 because of the size and weight
You could arrange your own courier - posting is at your own risk.
Price £575
21cm wide
18cm deep
76cm high
