ECL82se Amplifier By TANTHAI
Single 3+3 watt
OPT 5K8Ohm 15watt By TANTHAI
PT By TANTHAI
ECL82 *2
EZ80 RFT*1
Single 3+3 watt
PT By TANTHAI
ECL82 *2
EZ80 RFT*1
Hi. BasVery pretty and well executed build. What did the output transformers cost you?
180 us. for output transformers .
Hi. all
One D.I.Y. by TANTHAI
ECL82se
Rec. ez80 Philips Miniwatt
Power ecl82*2 Philips Miniwatt
Opt 5K8Ohm UL 100mA 15watt By TANTHAI
pt input 0-220
output 220-0-220v
0-6.3v 3A
0-6.3v 2A By TANTHAI
Power Output at 3+3 watt.
ECL82se
pt input 0-220
output 220-0-220v
0-6.3v 3A
Hi. all
6098/6AR6se
Rec. 5U4 , OC3
Power 6098*2
Pre Drive 12AX*1 , 12AU*2
Opt 5K8Ohm UL 180mA 50watt By TANTHAI
PT input 0-220
output 450-0-450v
0-6.3v 3A
6098/6AR6se
Rec. 5U4 , OC3
Power 6098*2
PT input 0-220
output 450-0-450v
0-6.3v 3A
- Vendor's Bazaar
- SE ECL82 By TANTHAI
