Scored preamp power supply, want opinions
Well im going back and forth between building the salas shunt regulator and using what i got now:
astec atv351
http://datasheet.octopart.com/ATV351-Astec-Power-datasheet-119783.pdf
it uses a ua723cn as a regulator
http://focus.ti.com/lit/ds/slvs057d/slvs057d.pdf
and a 2n6383 as the external transistor
http://doc.chipfind.ru/html/mospec/2n6383.html
Specs on the supply say its good for 3mv ripple, reg chip says 2.5uv noise with 80db rejection.
It will be used to power:
amb gamma 2 dac
active pga 2030 volume control
dcb1 buffer
