Does anyone have any information on Pass Labs preamp such as schematic? Does it use negative feedback? I saw a frequency capture of the XP-10 and the harmonic distortion is quite low which means some type of feedback was probably used.
If you visit the Pass Labs forum in the amplifier section, check the "Stickies" and you'll see some build guides and references to many of the products, preamps included. The XP-10, if not released to the community, won't be there. But there are lots of other designs to peruse. Also lots of articles at:
PassDiy
~Chris
PassDiy
~Chris
If its the X2 its available online where it states there is no feedback --plenty of zenner diodes though.
Do you happen to have the link?
Some THD measurement of the XP-10. The XP-12 uses feedback (not sure about the XP-10 though probably since they are similar).
Pass Labs XP-10 Stereo Preamplifier - HomeTheaterHifi.com
Your link states "in terms " that there is local feedback for the XP-10 but you haven't stated clearly which model it is you have --please do ?
Its a waste of time commenting on a model you haven't got as the information will be wrong.
Not sure what you're blabbering about.
Does anyone have information on the Pass Labs SIT/VFETS? Schematics of Pass Labs amplifiers that use the SIT/VFET?Does anyone have any information on Pass Labs preamp such as schematic? Does it use negative feedback? I saw a frequency capture of the XP-10 and the harmonic distortion is quite low which means some type of feedback was probably used.
- Analog Line Level
- Schematic of Pass Labs pre amp?
