schematic for marshall mg10
Well i think i have figured out where and how to ask my question. I need a schematic for a marshall mg10 practice amp. i know many consider these throw away amps but i kind of them. mine really has a good clean tone. thanks Any mods for these amps. Thanks again
Hi there,
I don'T have a schematic but you should contact Marshall USA (unless they are srill owned by KORG) and ask them for a service manual. These are very basic amplifiers, no doubt using some kind of TDA power amplifier IC. It's pretty simple to figure out. Maybe not the preamp section though.
What are you trying to do?
O.
pots had came loose from circut board and i replaced them but amp was not clean. It really sounded bad so i thought there must be another problem. I took it back apart and finally discovered i had wired one of the pots in wrong. fixed that and now is ok. Thank you very much for your response. dman.
