Hi all. I wonder if anyone can please point me in the direction of a PSU schematic.
I am looking for a well designed variable PSU schematic using IRF840 MOSFETs and LR8 HV regulator. It will be used for powering small valve amp projects on the bench and so I would not need anything above 300V 200mA max. Something with current limiting/short circuit protection if at all possible.
Any suggestions would be greatly appreciated.
Thank you
Thank you
What is your input voltage range? And does it absolutely need to be with that mosfet or can it use something else?
