Scarlett 2i2 gen 4 for amp measurements: Protection and Bal->SE questions
Hello, I'm currently building a chip amp based amplifier and want to try measuring distortion with my Scarlett 2i2 gen 4 sound card. I've seen some protection circuits and posts about earlier generation 2i2 but there are still some things I do not fully understand, and I'd hate to blow up my sound card.
First I want to ask about protection. I guess there are 3 things I need to consider:
  1. Amplifier power rails touching line in or line out.
    • I use 60V center tapped to power my chips. From what I understand I can use 2x 3.3v zener diodes to protect from this. Could someone elaborate on this? Why does the 1k resistor take up the load?
  2. Level too high on line in
    • I'll use a simple voltage divider for this so it becomes <1Vrms for my measurement.
  3. DC on line in.
    • First off, isn't line in already AC coupled? and if not, what capacitor should I choose so it doesn't affect my measurements? Should I also put one on line out?
Here's a picture of how I think it should look:
Another thing I wonder about is the balanced inputs and outputs. The user guide says:
Does this mean that I can choose whatever and it detects what I'm using? If I use a TRS jack, should I if so ground the right channel so the sound card thinks I'm using mono? I'd prefer using mono for simplicity. In this thread https://www.diyaudio.com/community/...r-measurements-whats-next.301166/post-4963930 @wintermute says that it's important for 2i2 gen 1 to atleast output balanced audio, but I'm not sure if it's the same with gen 4.
So, for my protection circuit, Could I simply add another pair of 3v3 zener + 1kR to the inverted output as well going into the linked bal->SE converter, and output that into my amplifier and keep the rest of the protection circuit same if using balanced output?
Last thing, why shouldn't I use speaker out - for line in ground? I know for certain amplifiers the speaker - is not ground, but if it's not ground how do I get accurate/any measurements by putting line in ground on line out ground instead? Since speaker + is referenced to speaker - and not line out gnd? This does not make any sense to me.
