Scan Speak R2904/7000 vs R3004/6620
Hi, I wonder what would be the best tweeter to use along with a 15W4531G revelator midbass, a R2904/7000 revelator or a R3004/6620 illuminator...
Anyone already worked with an R3004?
What about high frequency dispersion? Soft domes (like the D3004/6620) seem to be quite superior, but is this an issue?
Thanks!
Thanks!
Hi Filipe. The SS R3004/6620 illuminator looks better (on paper) in your case, with it's 90.5dB versus the 87dB of the SS 15W/4531G00, the low frequency output at around 2K and lower looks better, what the SS R2904/7000 revelator might be a pane to design a good xover and a lot of padding the high SPL. All in all I would considerer the SS D3004/6620 textile dome a much superior tweeter as you can see from it's specs.
Hi Inductor, thanks for your post! In fact the SS D3004/6620 looks better, considering FR and specs! The dispersion is also quite good, much better than a ring radiator.
Anyway I will upgrade from a SS D2905/9700 which is already a good tweeter. What SS tweeter would be worth the effort (and the money!)?
Whether this would be an economical upgrade is another matter as the ring radiators are extremely expensive.
I was talking to a chap who upgraded the D2904-98000 to the R29 ring radiator. He was pleased. He stated that the tweeters just vanished.
One thing to perhaps think about is that you might prefer a tweeter with inferior directivity, depending on how it interacts with your room.
I vastly prefer the way the XT25 sounds over the XT19, the only thing I can attribute this to is the inferior off axis performance. This is in exactly the same system in the same room with a well integrated xover.
