I guess this goes in the lounge.
Has anyone tested these devices? I've heard rumor that Capital Records used something similar in the 60-70s to add imprinting. No other details known.
I have nothing to do with the products or link. Just curious.
https://www.quantumbalancing.com/imprintingplates.htm
The attached pic is stationary , a parlor trick but interesting. I can stop them if view full size and stare at only one.
You should go back to the sources of all the buzz words here Mme Blavatski, Rudolf Steiner, Victor Schauberger and make up your own mind. Your figure does nothing in my perception, should I worry?
Think I still have a copy of Lakhovsky's book in english.
Several chapters describe a plant cancer he would use to infect samples,
then with grotesque stems he would cure the cancer and restore the plant.
Numerious bw pic plates.
It is interesting reading.
Scott, I would be somewhat concerned, On a reduced scale iphone it barely works but looks like a spinning gearbox on my laptop. neat illusion.
Here is a link to the original source bottom of page.
https://www.quantumbalancing.com/projects.htm
Not here, pretty hi-rez laptop. In any case the premises here is nonsense, waste your time if you wish.
