SB16PFC25-8
Has anyone used this driver from SB, and if so, how do you rate it ?
The Xmax spec is a bit lower than the other 6 inch SB woofers, but it is roughly half the price (due presumably to the plastic chassis).
I have used the SB13 (5" version) but I have heard this woofer paired with a Dayton RS28a tweet in a sealed (12L IIRC) and I was impressed by both. They will go low but not too loud bc of limited Xmax but are easy to work with and sound very natural due to the paper cone. Only drawback is flush mounting the pin-cushion frame IMO.
Sent from my iPhone using Tapatalk
I would probably spend the extra and get the SB17. Nicer (and round) cast frame, much better motor (Le is way lower), doesn't have a resonance issue just above 1kHz (blip in impedance and wiggle in frequency response).
Dayton RS180 has cleaner bass than an SB17, but the (upper) midrange isn't quite as good. I'd tend to use an RS180 in a 3-way and the SB17 in a 2-way (with subwoofer).
The next cheapest i'd go is the DA175-8. Similar bass cleanliness to an SB17, similar midrange to an RS180, half the price of both.
