• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Save $75 on XTZ Room Analyzer Acoustic Measurement Software - diyaudio.com exclusive
Save $75 on your purchase of XTZ Room Analyzer acoustic measurement system by using the coupon code diyaudio for purchases made via the Acoustic Frontiers website.
Coupon only valid until 02/11/2011 and for shipments to US and Canada.
XTZ Room Analyzer reviews:
"XTZ’s Room Analyzer is so easy and intuitive to set up and use" Stereophile
"A highly effective acoustic analysis tool that's simple to use and understand" Hi-Fi World
"After trying two other room analysis programs unsuccessfully, I was ready to give up. When I read about XTZ, with its "room analyzer in a box" idea, I thought I'd give it a try. It actually works. In fact, it works beautifully! It would be great if there were a Mac version, but even I, a PC hater, was able to get it to work. This is a great product." Dave 01/18/2011
Everything you need to measure your room in one box.
XTZ Room Analyzer includes in a single package an integrated measurement microphone/soundcard, upgraded v2 software, manual and cables. Putting together a measurement system from another source such as Room EQ Wizard, TrueRTA, For ETF will require you to purchase a separate soundcard, calibrated measurement microphone, cables and software package (and figure out how to connect it all together!).
All the acoustic measurement features (and some cool ones not available elsewhere!).
High resolution frequency response analyzer, operating from 16Hz-300Hz shows peaks and dips due to room modes and speaker boundary interference.
2D waterfall / cumulative spectral decay (CSD) / sonogram plot clearly shows modal resonances and how sound pressure level decays with time.
Proprietary algorithm automatically identifies major room modes and automatically calculates parametric EQ filters to nullify them. Add the Q, center frequency and gain to your favorite room correction processor to banish those modal resonances forever!
Parametric EQ simulator allows you to model the effect of up to 9 bands of parametric EQ on the frequency response and waterfall measurements.
Unique 'Stimulus EQ' mode allows you to measure the system through the parametric EQs you have selected.
32 band Real Time audio Analyzer (RTA) allows for real time monitoring of frequency response whilst adjusting speaker/listener positions, EQ, subwoofer crossover or other system controls.
Full range 20Hz-20kHz acoustic analyzer enables measurement of loudspeaker performance and identification of faulty drivers.
6 band RT60 measurement.
Automatic identification of loudspeaker / microphone distance allows rapid setting of distance / time delay settings in a home theater processor.
Thanks guys! Nyal @ Acoustic Frontiers
