satelites damping material
For those satelites im making, i'd need to add something inside em, i tought about cork on the walls, like 5 mm cork. How will that affect mids and i guess it wont affect the highs too much. And should i add a lil bit of polyfill (the box is a bit too small.... as i changed the mid driver)
And.. do you guys think braces could be needed? there wont be anything under 150 hz in that box.
