Sansui C1000 question!!!!!
Hello,
I'm willing to buy this preamp, I have a question to ask you; do you think if I connect a power amplifier to the normal preout, a power output to the "out processor" ... can it drive both of them?
Thank you
> doing the "Y" connection does not degrade the signal? ..
This preamp's "Output" can comfortably drive a 2K load.
Since modern amp inputs are generally over 10K, you can "Y" it out to _five_ power amps, maybe more, without any strain.
I once built a similar box with a slightly beefier "preamp" and 16 outputs. Some of those outputs ran to remote splitters with 4 more outputs.
When you get a rig that large, doing live recording, you also have to think about what happens when a wire gets shorted (idiot assistant, spike heels on stage wire, bad recorder...). But for a few splits in a playback system, no worries.
