I have came across a sampo 14.1" monitor for $175.00
the guy has 5 of them but the specs jost dont look legit.
i tryed to find other specs on the net but to no avail
these are his specs
LCD TFT
PIXEL PITCH 0.27 mm
RESOLUTION 1024 X 768
BRIGHTNESS 200 cd/m2 Typical
CONTRAST RATIO 300:1 Typical
DISPLAY COLORS 262K
RESPONSE TIME 10 ms
INTERFACE Analog R.G.B. 15 Pin D-sub
VIDEO INPUT SIGNAL Analog RGB video
VIEWABLE SIZE 13.8"
VIEWING ANGLE 140deg(H), 100 Deg(V)
USER CONTROLS All digital controls using an on-screen menu system
WEIGHT ~ 10 lbs
the response time looks fishy
anyone got time to find some info on this lcd
if all is good might make a nice lcd for ohp
these are his specs
LCD TFT
PIXEL PITCH 0.27 mm
DISPLAY COLORS 262K
RESPONSE TIME 10 ms
VIEWABLE SIZE 13.8"
WEIGHT ~ 10 lbs
i saw that montior on pricewatch, the specs on there say 200:1 and 20ms
Rekr
Search for 14in LCD at pricewatch.com
Rekr
was that a sowin 14" lcd you seen on pricewatch ?
i searched pricewatch and found nothing on a sampo pd-50fa
man i cant believe how hard it is to find a good 14" lcd
im new to this diy projector stuff
and i read every post in here
i just wish there was some way to make a 15" lcd work
aside from adjusting the screen size cause then u would be defeating the purpose of getting 1024X768.
and every pic i seen with a 15" lcd looks like the whole pannel wasent displayed
i was verry inspired by the diyer from china YWH i think.
his setup was unbelevable good show !
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- sampo lcd for ohp
