"S.I.P.E." (SIPE S.p.A. ELECTROACOUSTICS) looking for an old 8" Full Range Speaker with Foam Surround from the 1970s
A friend of mine at the time bought this full range speakers from me. Since I no longer have any contact with them and no longer have the supplier catalog where I ordered the speakers 1976, I can't find out the model No.
The driver looks similar to those from the first both attached image, but instead a cloth surround was a foam surround in use (for better results in the low frequency area in small cabinets).
The logo on the magnet of my old version was the same as to see on the other attached images.
Who know the model naming of this vintage full range driver ?
Thank you very much for an advice.
P.S.: in the attached data sheets from various models in 1985 the wanted model was no longer listed.
The German supplier on those days was Oppermann Elektronik.
Currently address and web-address:
S.I.P.E. S.r.l.
Società Ingegneristica Prodotti Elettronici
Via Alioli e Sassi, 24 - 21026 - Gavirate (VA)
Tel: +39.0332.746464
Fax: +39.0332.744473
E-mail: info@sipesrl.it
https://www.sipesrl.it
under
https://web.archive.org/web/20031201000000*/www.sipesrl.it
are no archived information to find
and under
https://www.ufficiocamerale.it/2750...tica-prodotti-elettronici-srl-in-liquidazione
I read this:
DATI DELLA SOCIETÀ - S.I.P.E. SOCIETA' INGEGNERISTICA PRODOTTI ELETTRONICI - S.R.L. - IN LIQUIDAZIONE
Indirizzo: VIA ALIOLI E SASSI 24 - 21026 - GAVIRATE (VA)
Rea: 233826
PEC: sipesrl@certimprese.it
  • sipe-1985.pdf
    sipe-1985.pdf
Hi. Did you find a replacement, did you send them for repair?
#1 Is it a full range?
#2 Does it have a crossover or is it ONLY One driver?
#3 Impedance?
#4 Size/internal volume of box?
#5 Is it a reflex (BR) or sealed (other speaker system design)?
#6 More specs like external size of speaker driver format? You show a catalogue, is it in there?
#7 Maybe with same or similar parameters (T/S parameters)?
Have a nice day.🤔💭😁
