Rusted OT Issue?
My output transformers got rusted in the storage. If I use abrasive paper to take away the rust, I'm afraid I will "connect" the steel so that in turn the lamination effectiveness may be affected. But I'm not so sure regarding the severity of this connectivity. How bad is this? What should I do?
i'd say leave it alone, if only the outside surface is affected....
or else you can use a wire brush mounted on a power tool to clean away the rust....you can dismantle the end bells and clean then and then re-paint......
as to the transformer itself, i doubt that there is an effect...
please post pictures of your opt so we can tell better....
