Running tubes at lower voltages
Hello folks,
I was thinking - would it be possible to run tubes at a lower voltage than what they're designed for (not heater, but grid(s))?
I am making a preamp, which needs to have a gain of only 2 (or something around there).
Can I use an EL84 or similar, and run it at maybe 100V or even lower - and of course still have things sound as bright, only not as loud?
Greetings,
-- Charl
You can run tubes at low voltages, but you will probably get higher distortion. Try having a look at the datasheets. But just try! If you like the sound it's good - if not try something else.
The playback amp of my r-to-r deck (5842 and 6N1P) runs well on voltages as low as 70-80V for instance - it normally runs on 330V.
You can get tubes meant for running on low voltages (ECC86 and EF98 for instance). I have also seen circuits running 6J5 triodes on 30-40V...
Best regards,
Mikkel C. Simonsen
Hello,
30-40v would be abolutely awesome, but 80 will do as well. Did you lower the voltages on your tape deck yourself or was it manufactured that way? And did the sound quality drop?
It's probably best to just make a test setup as you said. However, being relatively new to tubes, I don't know whether I can mess a a tube up by lowering the grid voltage(s). Is this so, or could it do no harm?
Thanks,
-- Charl
Yes, I manufactured it that way 🙂 (read more here: http://stiftsbogtrykkeriet.dk/~mcs/Tandberg/index.html
I designed it to run on 330V, but while testing it (with an adjustable supply), I tried running the circuit on lower voltages.
It did at some point (40-50V I think), but on 70-80V it sounded just as good as on 330V, but the output level dropped a bit.
I guess you mean plade/anode voltage? A standard grounded cathode triode stage has no grid voltage (the DC voltage on the grid is 0V). But you do no harm by lowering the supply voltage - but at some point it will stop working properly. Be careful with DC coupled circuits though. The stages may depend on certain voltages being present at other parts of the circuit. But in AC coupled stages or single stages there are no problems.
Best regards,
Mikkel C. Simonsen
Low voltage operation
One low voltage tube is the 6DJ8 or ECC88 or 6922 ( all basically the same ). You can run it well even at 30 volts.
I tried the ECC82 at about 40 volts. It works OK with some feedback in the circuit. It does have higher distortion than higher voltage operation or the 6922 series. But it sounds good. This however is not a "good" operating point and you could possibly hear the improvement in sound at higher operating voltages.
No harm experimenting and if it sounds Ok to you , its OK !
It shouldn't affect the tube.
The 6DJ8 can be used with ZERO bias voltage (grid cathode voltage) for very low signals like from an MC cartridge !
Cheers.
Hello folks,
Thanks ashok - I'll try to find some datasheets on those.
I just did some experimenting with the EBC91. Clipping occurs if the input voltage(of audio) - anode voltage ratio exceeds a certain level.
Ua of 140 of 120 makes no difference. When I lower it to 100, I can see that the output level begins to drop. At 80 volts, it's still dropping, and at 60V, clipping begins to occur. So, judging by ashok's reply, this isn't the tube I want!
Greetings,
-- Charl
Hello,
I have done some experimenting with since my last post, and would like to share the results with you and also ask another question.
I went out and bought an ECH83 low-voltage tube. Its frequency response drops dramatically from 15KHz and up. I might look in the future if I can prevent this somehow.
However, what I'm experimenting with at the moment is a good ol' EL84. Running the heater at around 3V, I have gotten some pretty good results - for my purpose that is (making a preamp). The gain is about 3.
There is one problem though. When I tried running the heater at 6V, the tube got very hot in about 30 seconds. I didn't think it was good for the tube to run this hot so I turned it off. (N.B. Va = 12V)
Thinking about this, it would be obvious - not 'enough' electrons are being pulled towards the anode, so they stick around at the heater - causing heat. Does anyone have an opinion on this?
Greetings,
-- Charl
PS. I know that I'm being rather silly using an EL84 as a preamp, but it has to look good as well 😉 If this doesn't work out I'll switch to something more common or maybe a higher anode voltage.
Hey Dedessus,
Could you please give me the title and writer of the article? I live in Holland so it might well be possible that they've published it in another issue.
I have about 150 old Dutch Elektors lying around (from 1984), and only ONE of them has an article about tubes in them! It's good news that they decided to do another article on them 😉
If I can't find the article, would it be too much trouble to scan it for me?
Greetings,
-- Charl
Running a 6.3V heater at 3V, he?
@3!)*&&^?
Yeah...I do. Go through some books first or stick to candles...They light up nicely too.
Good luck,🙄
Redemption,
Oops!!
While your experimentation is great, you are seriously wrong if you think an EL84 with 12V on the plate and 3V across the filaments runs too hot!
These tubes run very hot in operation, with a Va of around 250V or more, 25mA, and 6.3V filaments.
There is definitely work from Steve Bench demonstrating conclusively that the harmonic structure of tubes varies with applied voltage, and there is considerable evidence that reducing a 6.3V filament to around 5V (AND NO LOWER!!) will increase H2 while slightly reducing H3. This MAY improve the sound; I've not verified it.
If you underrun a filament at less than half voltage its emission will be very low, and it is very likely its current flow will actually be greater since the filament is much colder. This higher current will cause more molecular 'corrosion', and likely result in carbonizing and lower life.
I strong suggest a higher filament voltage, and if holding the tube for a merest fraction of a second is unbearable, it's probably running at the right temperature. These beasts run VERY hot, and they designed to tolerate such heat with ease.
Hugh
Hugh, fwiw, I know several designers (Dave Berning, for one) who swear by reduced heater voltages. The classic TF-10 preamp used about 22V for two 12AX/AT7 heaters in series. My own preamp does the same- the 6KN8s are run on 5.9V, the xxxx-super-secret 12V tubes are run on 11.5V. I'm quite happy with the sound- or, i should say, the lack of sound. Haven't quantified the change in distortion spectrum, but I have noticed a bit cooler running and longer tube life.
If I were to design a tube preamp to run on low anode voltages, I'd be thinking Nuvistor. Then I'd walk around a bit, get a nice stiff drink, and talk myself back into using sensible voltages and sensible tubes.
Little sidebar:
Steve Bench's test were run on DHTs IIRC as an exercise how the heater voltage influenced the tube's curves.
For the less brave, stick to the +/- 10 deviation as per the manufacturer.
Better still have the heater voltage spot on.
Cheers, 😉
Hello folks,
AKSA - Thanks a lot for your reply. The tube doesn't get hot to the point where I can't hold it any more. I'll make sure to run the filament on the correct 6.3V. I'll keep y'all updated! 🙂
And to all the sarcastic people out there - I'll probably move to some higher voltages later, but this is the easiest way to get things working - and learning - without hurting myself.
Greetings,
-- Charl
.......but this is the easiest way to get things working - and learning - without hurting myself..................
Go for it man ! !
There are no strict rules to be followed in the DIY game. Just make sure you stay within the safety framework.
Have fun . If it ceases to be enjoyable .....give it up !
Cheers.
Ashok.
