Hi. I recently acquired a rowe ami jukebox that plays cds. Model # CD-100E Serial number 1493 It played cds no prob..Volume was great as well. I then decided I needed the lights to work.
there are 4 little white switches (lamp control music and standby switches) which I moved into different positions. I then tried to play a cd again and nothing. If it attempts to pick up
an empty slot u can see the laser bounce up and down and the silver piece the cd sits on spins.
However it does nothing with an actual cd on the laser part. As u can probably tell I do not know alot about these things. Anyone have any ideas/suggestions as to what I might attempt in
order to get the cd player working again? any and all help will be greatly appreciated.
Shawn
Shawn
Did you try moving the switches back? Especially the standby switch? If there is a switch marked service/operate or something like that, try it. And have you closed the box? I don't recall the innards of that one, but a lot of them have a little flap that pushes a switch back into the operate position when the cover closes. I don't know what you did, but I suspect you put the box in service mode.
Here's a site that has all the manuals for the "CD-100e" in pdf for free DL.... Hope this helps.
Rowe Jukebox Manuals
