I've been working with NE5532 dual op-amps and I could not find a way of routing the power supply pins of multiple op-amps together and to a common supply connector on the PCB. Any ideas on how to do it?
Use power and ground planes.
Persist and all will be revealed 😀
Seriously though, I have had some difficulty with this on single sided boards - wire links on the topside are a simple way of doing this.
I have a PCB in my gallery page (I think) which shows a scheme of power connections, and also some tips and advice from other members on a similar project.
Search the forum for "filter Q Question" and you should see the thread I started and the advice other gave me about layout of power and ground.
I have used ground planes before, but not power planes. Can it be done with single sided PCBs?
Sure, if you give the layout some thought. Just not as effective as multilayer planes.
