This forum has been very helpful in the past and this is my first time posting. So, thanks in advance.
I have a Rotel RTC-850 preamp tuner that I picked up recently on CL with matching amp. The components had been in storage for some time. The amp is good, but the preamp is a problem.
When I turn the preamp on, it gets power (28-29v to the filter caps). Output is only a hum with no music. If I play with the switches, the hum goes away... but still no music.
There is no display either. Only the red power light on the volume knob stays on. If I keep the tuner selector depressed, it does display and am even able to change stations. However, the tuner display goes away as soon as I let go.
I am no tech but have cleaned everything with deoxit twice. The caps 'look' good. The fuses are intact. Any ideas?
The real question is whether or not this is worth pursuing...
Thanks!
Thanks!
