Rotel RCD 951 left channel dead
My ancient Rotel RCD 951 left channel stopped working, just died in the middle of the song - silence. I/V converter & output buffer (2604) is not an issue, tested OK. It seems that signal from PCM69AP is not good, but I have no experience with DA converters... Buffer part of the 2604 on all inputs (pins 5 & 6) and output (7) measures ~14VDC. Pin 3 on the I/V part measures ~3.4V but pin 2 (-in) 2.6VDC, only. Pin 1, output of the 2604 I/V converter ~14.5VDC.
Power supply is OK there is around +/- 15VDC on pins 8 & 4.
Schematic is on the page 10, service manual attached.
Any ideas are welcome.
Cheers
