Hi
I wonder anyone came across a Sanken S1-1725HDF power amp IC module used in this Rotel amp. It has 16 pins and looks like the STK series amp module. I cannot find any info about this module on the net. Does anyone has any info?
Carlos
Carlos
I found no info on the Sanken module, but a company in my country sells them for about 4 GBP per piece....
It is SI, not S1.
SI1725 HDF Sanken végfok. | Kovács Elektronika
It is SI, not S1.
Hello dragonweed!
I have the same problem as Carlosraj, I need a Sanke S1-1725HDF or Sanken S1-1725HD to repair an old Rotel RW-500. I found that Kovács Elektronika is still selling the device in their webshop. Unfortunately the webshop uses only hungarian language, which is fully unknown to me. Could it be possible to get some help from you regarding the language problem?
Martant
Martant
You can googletranslate the webpage to english.
They seem to have one piece at the moment.
Under "Kapcsolat" you can see their email address, probably the best way is to contact them.
Google gave this result also. But they are not in Hungary.
Well, in the Hungarian store there is only one left for sale, the Danish site still has them, but a bit more expensive (about 5X) 😀
