ROTEL amp sounds dull
For years now I have a Rotel ra980bx amp. It's sounds pretty good, but only after playing a few hours (loud). The difference is quite big. In the beginning the sound is lifeless and mechanic, not spacial at all. High frequenties sound a bit sharp. The sound isn't distorted or anything.
Do you have any idea what the problem might be and how I can solve it? I'm pretty sure it's the amp, because when I use my headphone (Sennheiser HD600) it has the same problem, also on on a different source (radio). For years I thought the speakers where the problem (Vifa Vivace '89 model) and did quite a few mods to try to fix it (Leclanche caps, tritec coils, wires ect) but not with the desired effect. I also asked around at hifi dealers but the only answer I get is "keep the power on" but that doesn't help. I already cleaned all the contacts and used contact spray cs90 for all the switches. Any suggestion?
Yes, amp might be a problem (for various reasons: changes in BIAS setting and components characteristics due to elevated temperature etc. etc.) but also always have in mind that your speakers are heating accordingly after few hours of loud music!!! Measure temperature of coil and magnets if you can and you will see. Don't think that there is no any change in behaviour and sonic of your drivers during prolonged high power sesions!
My guess is that "for years now" means a considerable number of years.. in which case the power supply capacitors are probably past their prime and in need of renewing.
Rotel should give you the service manual for the amp if you email them.
It sounds like a bias problem to me. I think you'll need to either have the bias checked at a shop, or get the service manual and a decent multimeter so you can check it yourself.
One other question, though: how warm does the amp get when left on for an hour or so at idle? Does it get warm above the heat sinks or does it stay fairly cool?
Our ears plus brain adjust everything.
When you continue to listen, after the first seconds, the brain starts to proceed with "processing".... after long listening..all hell bad amplifiers will sound good.
Switch on and wait some minutes to circuit stabilization..then play the music flat...in three seconds you have the real evaluation..if bad...sound is bad.
If was different than that..... brain not doing nothing together your ears, then people talking will disturb your telephone audition turning impossible to understand...and this do not happens..in seconds your ears will adjust... depending the girl is in the other side you will listen ABSOLUTELLY NOTHING THAN THE GIRL!
Also portable radios, the ones have no bass, absolutelly no deep bass reproduction..amplifiers cutted 400 Hertz and down this frequency would be reproduced without any bass...but you switch on and go listening and brain introduces (equalizes and uses auditive memory and previous musical experiences to fill the gaps) the bass you want to listen.
Sounded bad into the first seconds...shut it!.... shoot it!...booom!
Bad amplifiers drives you tired during long listening..because hard work to "process" all that stuff into your brain... you adjust and re adjust tones and never feel satisfied... because sound is really bad to your human ears plus brain..... good amplifiers are less tiring and you can listen for long time without tweak tone controls....if you tweak, constantly... seems sound not good..and you are trying to send to brain something more clear.... we say recording not good..ahahahahahah!
Use decent recordings, and select the richest parts, where you have more harmonics, more rich instrumentos, more ballanced tones... parts you like, parts you know... alike, in my personal case:
Vangelis - New Age - Mystik - Gregorian - Medieval
regards,
Carlos
Helps too... and we can blame the spray because...
...made noise when the spray was out... the contact memorized the noise and when the amplifier reproduced once again that noise was free to produce interferences.
In some way this remembered me the Greek audiophile club of Athens... the one was spitting some powder into the vinyl disc to avoid statics.... he said was introducing some "spice" into the sound... salt and condiments.... i use to watch that movie into youtube and i laugh all time long.
ahahaha...just kidding.
of course contact cleaner helps Jacco.
Carlos
Athens audiophile Club from Greece:
http://www.youtube.com/watch?v=xs1aUws0Lrs
I love to watch that movie Sakis
Those guys made me laugh those last monthes.
regards,
Carlos
Carlos,
i pull your leg, you pull mine, sounds reasonable. :clown:
Seriously, check out the number of contacts between input and the power amp section in the service manual of the RA980BX that i posted.
Contacts can be a problemo major, depending where one resides, when i look outside the window at home on a clear day i can see oil refinery flare pipes in several directions, i stopped using silverwear ages ago.
A poor man's integrated Krell biased too high ?
(i became an audiofreak because i'm a nut)
Thanks for the reactions; didn't expect to have so many allready! I really appreciate it.
The amps is about 14 years old; should the caps be renewed? I remember from years ago (10?) that I had the same problem.
I'm pretty sure it's not just my ears of brains. It can't be that much of a difference. By the way, I don't listen for hours, but walk away and come back when the stereo played for a while.
Maybe I'll check the bias then, but I have no idea how to. Where can I find information about that? I do have the service manual.
I'll checked the termperature when it's idle. From the outside it feels warm, not hot. Does that say anything?
IIRC, the RA-980BX was manufactured between 1992 and 1995.
There are 2 testpoints (TP) at both output stages, indicated in the top view of the amp in the service manual.
With a digital multimeter you can measure the voltagedrop across one of the white MPC70 emitter resistor blocks.
The trimpots VR601/VR602, which adjust the bias of the output stage, are also indicated in the top view drawing.
The SM says to adjust to 10mV, that's 45mA current through each of the 6 output devices.
With 6 power devices, the output stage of the 980BX is pretty sturdy for a 100W amp.
3 pairs of B817/D1047 handle 600W max dissipation, 6 times the continuous power in 8 Ohm is rather good.
The reason that Rotel chose a Pd/Power factor of 6 is because it lacks sophisticated protection circuitry, merely switches the power amp input to ground with a relay when the output current reaches 15A or when the heatsinks become to hot.
I'd check that relay if i were you !
First action would be to verify if the output stage is indeed biased at the advised 10mV, and not lower.
10mV is a low value, much better for an AB output stage would be 20-25 mV.
20mV is an extra 15 watts of idle dissipation per channel, each of the output devices can easily handle an additional 2.5W of heat.
You'd have to try it to see if the size and ventilation of the heatsinks are adequate enough for an increased bias.
Your Vivace loudspeakers are a very easy load for an amplifier. Afair, the minimum impedance of the first series 3-way LSP's is somewhere around 6 Ohms with an efficiency of 89dB/w.m
Checking the vitality of the PS electrolytics is more difficult.
Replacing four 10.000uF/63V would be a sound investment for a decent integrated as the 980BX.
Electrolytics have become both better and relatively cheaper, an exchange would cost around €35 if you order some parts at Digikey.
I adjusted the bias and what a difference!! It's sounds so much better! The only thing is that one of the emittor resistors looks a bit black. I checked it and they all seem to be 0 ohm on my multimeter but on they should be 0,22 Ohm K (that's 220 Ohm?). So are they all burnt? On them is written: "MPC70 0.22 Ohm K fil 2502".
Also the bias seems to drift. When I set it at 10 mV it 'll be 20 or so in a while and next time I switch it's different as wel, though it won't get past 25 mV or so. Left and right are different (like 5-10mV difference). Is that a problem?
And about the caps: I ve seen lots of brands on the internet. What would be a good choice in my amp? What about these: Nichicon Muse KG 10000uf 63v at 90 euro? I couldn't find any at digikey btw.
Bartt, I think you should replace the emitter resistors, your bias shouldnt be drifting so much, Ive never seen this on rotels. As for the caps, I think they are still good, I have some rotels with 20 year old caps which are still good, they use high quality slit foils, far superior to the common muse series. If you do want to replace I suggest you contact rotel and replace with originals.
I don't buy this. I would first like to know how Bart did the adjustment.
In general, the amp should probably have been idling for at least 20 minutes before you start. If you had to turn the idle up a lot, then let it sit again for a few minutes to stabilize, then recheck, readjust, etc, until the bias is where you want it, and is probably drifting around within 1mV or so +/- of where you want it.
Then you should run the amp at pretty good power (say 50W or so) for a few minutes, and then allow it to settle back down for five minutes at idle. It should return to the point where you had adjusted it before.
If adjusted the amp before it was warmed up, or didn't allow enough settling time between adjustments, then I could certainly see the types of deviations you're talking about.
Others can probably provide some better tips on the bias adjustment process. This procedure has worked well for me, but I may well be missing some points as well.
Paul
I recommended the replacing of the resistors as these are a weak link in all rotel models, they simple dont handle the power too good, I have 9 rotel amps and had to do this at some time or the other especially the more powerfull models, the value undergoes some change after some years use if you turn up the power and Bartt has said that some seem to be a bit black. The zobel resitor should also be checked as these fail after some use and become open circuit and the amp can have slight oscilation with some speaker loads which can cause the heating of the output transistors. It is important to check this as this amp uses no output coil.
The bias has to be set with the amp warmed up as specified by the owners manual.
I haven't come across low value wire wound resistors that drift significantly in value with time and use. Could it be a problem with the junction of the lead out wires of the resistor and the resistive element ?
Bartt: that is 0.22 ohms and maybe your meter cannot measure low value resistors which is why it reads 0.
A friend with an Audiolab amp accidentally discovered that the amp sounded much better when it was 'hot' . That happened one day when something was placed on top of it hindering air flow. After a while we realised that the amp sounded much better than it usually did.In about half an hour it had become quite warm.
Obviously the dc bias had gone up . I couldn't do any electrical checks and before I got another opportunity , he sold it .
I have a Rotel RA970BX . I bypassed the input circuitry and connected the input selector switch directly to the volume control and that was connected directly to the power amp via a Solen cap ( original was a Blackgate ). It has completely transformed the sound of the amp. Sounds very nice now. Maybe I should bypass the input selector also. Right now the input switching is useful but maybe I can have one input direct wired.
That would make it parallel with all other inputs IF it's plugged in while the others inputs are used. I can live with that. Just have to make sure that input isn't connected when the others are used.
