First, I'm cheap.
Looking at gold point stepped attenuators I balked at the pricing.
I decided to see what people were saying about the cheap Chinese stepped attenuators on eBay.
I couldn't find much but after reading a lot on the gold point web site, I knew that the basis of a good stepped attenuator is a rotary switch with shorting contacts so I started looking for one and found a Centralab PA4002.
When I searched for that part number, I found an article from 1979 using that very switch as a stereo stepped attenuator.
The article was written by W. Marshall Leach Jr. and can be found toward the bottom of this web page:
Dr. Leach's Amplifier and Speaker Projects
It seems pretty straight forward but most things 35 years old need a little refresh.
If anyone has positive or negative opinions on this type of stepped attenuator or the switch I'm using, I would love to hear it.
Any way, I'm still cheap and I'm thinking I should buy a quantity of one resistor value to make a linear taper and use a law faking resistor to give it audio taper (idea borrowed from ESP).
That idea satisfies my cheap side, its less math and the parts order will be way easier.
That all seems like a good idea to me but once again I would love to hear some more informed opinions.
I've also got ideas for a cheap balance control but let's stick to the stepped attenuator for now.
Thanks for all the opinions and help.
23-positions is simply not enough. You need 1.5dB max 2dB steps, and at least 60dB range. High precision resistors are not necessary. I would use 5% SMD resistors, and true log, not law-faking. Calculation is easy on an Excel table, but I am sure you can find it readily on the net.
23 positions not enough? I have 6 positions on my shunt attentuator, and only use 3 of them (the 3rd is only used for DVDs which always have a lower volume than CD). In reality I only need position - loud - but my wife always tells me to turn it down when she is the room.23-positions is simply not enough. You need 1.5dB max 2dB steps, and at least 60dB range. High precision resistors are not necessary. I would use 5% SMD resistors, and true log, not law-faking. Calculation is easy on an Excel table, but I am sure you can find it readily on the net.
Hi Lead Ear,
Im in same position as you, planning to build my first stepped attenuator also.
I bought pair of these, now waiting them to arrive:
PP36 21 Russian Military Rotary Switch 35 Steps 2 Plates 2pcs | eBay
First thing may be checking contact surfaces and then using some of those internet calculators for correct resistors values.
-Skoo
-Skoo
Hmm.. This sounds good.
Attenuator i mentioned in earlier post above has 35 steps.
So, i can divide those by two and maybe try Takman Carbon and Takman metal film in same attenuator and compare sound. Only have to decide whih design to do: shunt, ladder or series.
- Analog Line Level
- Rotary stepped attenuator (series) instructions?
