Roland SRA 540
I am trying to solve a problem that I am facing with this power amp. Both channels are working alright but there is a distinct buzzing sound from the second channel. Without any signal plugged in and with the volume totally off, there is still this buzz. It sound something like if a microphone cable shield is removed, you can hear a distinct buzzing sound. I checked to see if there is a break in the ground and shield connection, but it is intanct. This amp uses a single toroidal transformer, but separate rectifiers and filter caps for each channel. Can this buzz be coming from the power supply. Please advice.
Carlos
