roland jazz chorus-55 amp repair
H i have an old Roland jazz chorus-55 to repair and need help with a few things.
1. the reverb pot is missing and don't know what value to replace it with
2. i cant find new output transistors (2sd1408 and 2sb1017) any ideas where i can get them or an equivalent
IF there are any other pots, check those.. they are probably similar values. I doubt the pot is critical - try a few values. 100K is probably a good start.
For the output transistors, well you could use MJE15034/5 or similar. They are faster so watch out for stability issues, but otherwise they should work well.
