Roland FA-76 Problem!!
hi guys, i need your help, my keyboard doesn't have output sound anymore and i have check on it and found 5 capacitors in this area are blowned, i replaced this caps but still without output. I dont know if the Opamps are working, anyone have ths service manual for this model?? or just the output area schematic?? this is my email: :cop:email removed tp protect against spam. Please PM :cop:
greetings from TJ
I have no schematic, but even without it, look for the power supplies. The analog section should have op amp ICs rinning on probably +15v and -15v, or possible a pair of 12v supplies. Look at the power supplu p[ind of the op amps near the output jacks. Or for that matter ANY op amps in the unit. Are both power supply pins powered?
I can;t see your unit, but when a bunch of caps are blown apart, usually it either means power supply failure, or it means someone plugged something into the output jack that had voltage on it, like for example the output of a power amp, or even just something not grounded to the mains.
Enzo thanks for your time, i checked the voltage in the output area, looks like the voltage is not the problem i have +/-15V in pin 4-8 (ic 5532 opamp), but i dont find signal in the output pins (1 and 7) thats why i need the schematic, i need to know from where the sound comes and follows the signal and see where it gets lost, because i have the signal in the fiber optic output, looks like the sound card its working good, any advice??? or maybe i just need to change the ic 5532, can i replace them for a ic 4580???
I have no knowledge of this product, but in genera, if the power supply is there, connect the unit to an amp and touch the input pins of the output op amp. Use a small screwdriver or a piece of wire. This should inject some hum, which you would hear if the stage was working.
DOn;t overlook simple things like failed volume slider. After jack solder, that is one of the most common causes of lost output on keyboards in my experience.
Can Roland provide the schematics?
