There was no sound from the amp. When I plugged direct to the "main in", there is sound, so I suspected the pre-amp circuit. Upon checking I realised that the (-15V) to all the ICs was missing. One of the zener diode has shorted but could not figure out the part number as the number on both diodes (D1,D2) was disfigured, that is why I needed the schematic. After replacing this diode the amp is working fine.
Thanks again,
Carlos
Thanks again,
Carlos
