Rockford Fosgate T15002
I have a rockford t15002 that came in for repair. Initially I found 2 shorted audio outputs. One 28n15 and a 36p15 along with large 0.1ohm resistors. I also replaced all the power supply fees because it was drawing excessive current with the high voltage removed from audio board. After replacing the pws FETS I powered up the pws board and everything was working properly. I have the bias pots fully ccw and just powered the audio board with j18 and left hv off. The amp powers up, the fan comes on, and the thermal light blinks. I don't believe the problem is with the thermal circuit I may have missed a driver component that has failed causingredients other issues. Does anyone have the schematic for the T15002. Pc-4701-A
