Depending on the year, they had a few variations. I have a few P3001 parts boards from 2005 and they all use 60.4 ohm gate resistors.
Those are a metric package size I believe. Similair to 0805 size but they use a different number as a package size.
0805 = 0.079 x 0.049 in. typical power rating is 0.125 watts
2012 = 2.0 x 1.25 mm typical power rating is 0.125 watts
The 2012 metric is equivalent to the 0805 standard.
Either way 60.4 ohms is what you need.
I just got the new fets and gate resistors..
I soldered in the new gate resistors and wanted to check the gate signal before putting the new fets in..
Should i have 5 volts on both gate pads for the fets ?
Im only seeing 5 volts on 1 of the gate pads (Q1090)
Q1001 doesnt have 5 volts and isnt showing a squarewave on it as well..
So wondering if this is normal for this amp or do i need to trace the circuit back ?
