Rockford Fosgate 2000 Watts Max
TO-3 said:
Easiest way is to stick a pin in the center and carefully pull the dome out.
Bend the tip of the pin 90 degrees. It will work pretty good. I did it to a pair of Cerwin Vegas a long time ago. Some of the wrinkles may not totally disappear, but it will look better than what you have now.
turn the speaker around. stick the eraser end of a pencil thru the vent hole in the magnet. push the dent out with the pencil. u can also use duct tape on the front of the dust cap. take a piece of tape , it has to have good adhesion. push the tape hard to the dust cape. pull. dent should come out without making a nasty hole from a pen, yuck.
