rocker switch
the switch *should* match your usage specs... but it is <i>possible</i> that you could safly use a 120v switch in a 220v enviroment although i wouldnt recomend it simply becasue you should use the corectly rated hardware. I would definatly stick with the same amperage though....
>> I just wanted to know if they have to go by the voltage or amps? e.g. 10A/120vac.
Both!
First, your switch has to be rated for 120VAC use.
Then, it has to have a rated current larger than your load.
For a 250 watt load at 120 VAC, you expected current is
250 divided by 120 = 2.1 amps
To be safe, get a switch rated at least 4 or 5 amps.
Need some recommendations?
Look here:
http://www.allelectronics.com/cgi-bin/item/RS-128/700400/DPST_ROCKER_SWITCH,_16_AMP_.html
http://www.action-electronics.com/switches.htm#Rocker
http://www.meci.com/index.php/cPath/132_335
