Robust Driver stage recommendations
Hello DIY audio-ers,
I am looking for a driver stage to drive two KT-88s to AB2 in triode mode. Maybe even KT-120s if I feel the urge. I have all the expensive stuff purchased (Power transformer, OPTS, all that good stuff), and a pretty standard input stage, now all I need is a good PI and Driver. Any suggestions? I like Tubelab's octal driver circuit, but is the design sea worthy?
Any Help would be greatly appreciated, this amp will cook as soon as I get it up and running.
-Moose
The octal driver circuit was designed in this thread in response to a question asked by member chrish that provoked my curiosity. It took 2 years and several diversions but Chris finished his amps and is happy with them. I built a breadboard and ran it through my usual abuse testing with good resuts. The breadboard still exists, and still works but I haven't made a complete amp yet. Yes I used it to crank 75 watts per channel out of EH KT88's in triode mode. I have also cranked several types of sweep tubes and other tubes with this driver circuit. The breadboard is saved for eventual comparison with another driver that I am currently developing.
http://www.diyaudio.com/forums/tubes-valves/133034-6l6gc-ab2-amp.html?highlight=6l6gc+ab2
Pictures of Chris's beautiful amps can be found in post #111 here:
http://www.diyaudio.com/forums/tubelab/157491-pictures-your-tubelab-amp.html
I have spent a lot of my rather limited spare time abusing and learning about Petes magic red board. This design won't do AB2 and is meant for sweep tubes. I am experimenting on another version of my driver circuit using pentodes in one stage and triodes in another with PowerDrive for AB2 operation. This is based on some of the things I am learning on Petes board. It will NOT be done any time soon. Petes board with minor modifications can make stupid amounts of power with cheap sweep tubes. My current version makes 125 WPC from $5 output tubes! I have seen 250 WPC from tubes that I got for $4 each.
http://www.diyaudio.com/forums/tubes-valves/151206-posted-new-p-p-power-amp-design.html
