The Robotics Masters Robo HAT MM1 is an open source robotics controller board for Raspberry Pi. It removes the initial barriers to starting any robotics project by providing all the hardware you need in one simple, easy-to-use form factor. The board is also compatible with Jetson Nano and can even be used standalone. The Robo HAT MM1 removes the need for a PWM driver, external power, or voltage regulators, and adds additional functionality. Wide compatibility with many open source software libraries such as CircuitPython, SeeSaw, and Arduino IDE means that you can use Robo HAT MM1 in the way that works best for your specific project. The hardware schematics and software will be fully available and open source.
Robo HAT MM1 | Crowd Supply
