rj6 coaxial cable to wire the input connections to the input/driver tubes?
Guys,
Just curious.
Can I use regular rj6 shielded coaxial cable (the one used for TV cabling in your house) to wire the input connections to the input/driver tubes in a vacuum tube amp? Or any other vacuum tube project (e.g., phone preamp, etc).
Or do I need to use the "lighter" shielded cable used in these type of projects?
Any response is appreciated. Thanks,
You could, but you need stuff with a pure copper center conductor, not copper clad steel. Numerous versions of RJ6 are available. Is the stuff you are considering truly satisfactory?
IMO, you are better off using wire intended, from the start, for audio.
RG6 is very big, stiff and awkward. I prefer to use RG179 coax. It's silver plated copper clad steel on the center, then Teflon™ and silver plated copper for the shield. It's thin, flexible and easy to work with. And it's low capacitance too for it's size. You can often find it in short lengths on eBay for pretty cheap. Plus it sounds good!
Yea, I use RG174 also but it's got a little more capacitance per foot.
