RGB Wiring?
Info?
I am incredibly far from knowledgable in this area but I'm pretty sure you will need to give more specific information. Do you mean a red wire, a green wire, a blue wire and two all black wires. See what I mean?
good luck
I had an old high end (when it was made) 21" monitor that had BNC connections like that. I'm pretty sure that each connector and cable was 2 connections positive and negative or whatever you want to call it (or it's called properly) to make a complete circuit. Do these wires have two conducting wires like coax or something like that? I assume that you have already checked to make sure that these are the only connections that were ever on it. As I said I'm no expert so someone else should jump in and help.
