RF Power 1001bd Dead... but how??
I've had this amp for a while, hasn't been used in a while because I pulled it out of a car I traded in. Its been sitting on a shelf collecting dust. The amp worked perfectly when it was removed from the car. However looking to get back into installing some gear in my current car and was testing out amps and this one seems to magically be dead now. Was hoping to get some ideas on where to start troubleshooting.
upon hooking up to 12v source the amp has a short spike of current draw (i'm guessing this is internal caps charging up)
once the remote wire is connected to 12v the amp has a current draw of .02 amps...
Its like the amp forgot how to turn on or something
any input would be great
I've attached the layout but if the protect LED never comes on, it's probably not U21. Is the remote terminal loos where it goes into the amp?
that was the first thing I checked, when I first got this amp it had a bad connection there so I resoldered it.
Pin1 :0v
Pin2 :0v
Pin3 :0v
Pin4 :0v
Pin5 :5.04v
Pin6 :9.80v
Pin7 :0v
Pin8 :0v
following the trace from the remote on it appears to end up at pin6. with the remote not connected there is 0v on all pins
DC voltage on LM339 and SG3526?
lm339
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
3526
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Pin 17:
Pin 18:
lm339
Pin 1: 0
Pin 2: 0
Pin 3: 17.5
Pin 4: .08
Pin 5: 1.73
Pin 6: 5.72
Pin 7: 5.04
Pin 8: .01
Pin 9: .01
Pin 10: 5.04
Pin 11: 10.79
Pin 12: 0
Pin 13: 0
Pin 14: 0
3526
Pin 1: 4.99
Pin 2: 0
Pin 3: .91
Pin 4: .24
Pin 5: 4.83
Pin 6: 0
Pin 7: 0
Pin 8: 0
Pin 9: 3.68
Pin 10: 2.12
Pin 11: 0
Pin 12: 4.94
Pin 13: 0
Pin 14: 17.6
Pin 15: 0
Pin 16: 0
Pin 17: 17.6
Pin 18: 5.04
it got dark outside so I came in away from the car battery so yes I hooked up the charger, didn't figure it would hurt it any worse at this point. the voltage at the amp terminals is 15.4. Should I hook back up to the battery and take the measurements again?
ok back outside and took some readings hooked up to the battery things have changed around a little bit
m339
Pin 1: 4.53
Pin 2: 4.53
Pin 3: 11.84
Pin 4: .06
Pin 5: 2.34
Pin 6: 3.93
Pin 7: 5.04
Pin 8: .01
Pin 9: .01
Pin 10: 5.04
Pin 11: 7.42
Pin 12: 0
Pin 13: 4.53
Pin 14: 0
3526
Pin 1: 4.99
Pin 2: 0
Pin 3: .91
Pin 4: .24
Pin 5: 4.83
Pin 6: 0
Pin 7: 0
Pin 8: 4.53
Pin 9: 3.68
Pin 10: 2.12
Pin 11: 0
Pin 12: 4.94
Pin 13: 0
Pin 14: 17.6
Pin 15: 0
Pin 16: 0
Pin 17: 11.84
Pin 18: 5.04
sorry, pin 14 should have been 11.84 like pin 17. The remote wire is jumped over to the B+ terminal. B+ is coming off the battery through a 10 amp fuse as suggested. for the resistance if my multimeter is set to 2000 it reads 584 with the neg. probe on pin 4 and positive on pin 15.
However if i hook it the other way, I have to set the multimeter to 2000k and it reads 1660 and keeps climbing.
It appears that the 3526 is defective. I don't see anything preventing the soft-start capacitor from charging. It doesn't appear to be shorted. That would leave the 3526.
Connecting a jumper from pin 18 to pin 4 'may' force the IC to function but you'd have to have a relatively small fuse (15 amp) in the B+ line before applying power to help prevent serious damage if the IC doesn't produce the right output.
