Rework at pair of 15" sub boxes to fit RCF L15P540 drivers
Hi, I have gotten my hands on a pair sub boxes for 15" speakers made from 19mm MDF fiber wood. I also have a pair of RCF L15P540 drivers.
I would like to create a pair of PA sub woofers I can use as a component set, together with a pair of full range PA speakers.
The boxes are rectangular of outer size: hight: 59cm, width: 54cm and height: 45,5cm. This gives a total volume of around 123 liters as far as I can calculate. The driver hole is made at the front in the middle almost. The boxes are not vented right now, however I would like to add bass reflex ports - I think. The boxes are sealed but not reinforced/stiffened internally.
https://docs.google.com/drawings/d/1Hawkd6yeW8n0hfWEnCAvnZXvZLqZ6DF8LSJwEcn4K4g/edit?usp=sharing
Now comes the big question, are these boxes at all suitable for a pair of ported subwoofers for the drivers I have at hand?
If so, what size of ports should I use?, How heavily would you dampen the speakers with dampening material?
If the boxes are not straight suitable, can I modify (make the boxes smaller) to better fix the drivers?
I rather like those RCF drivers. Had one in a Tannoy T40 cabinet, and it sounded really nice. 40Hz with authority from a single 15" in a 100L box was a nice thing to have. Unfortunately, I burnt it with an oversized amp (600w) and a compressor. Stupid...
Anyway.
123L net will probably give you 100L internal volume to play with. There's not a lot of Xmax to play with, so you could probably get away with a pair of 4" ports, tuned for 35Hz. You can use WinISD or Hornresp to calculate the port lengths.
Make sure you've set a high-pass filter below that to stop them bottoming out.
Hope this helps
Chris
