Hi, apologies if this has been asked an answered somewhere else but I couldn't find it. I'm trying to merge a diffraction corrected Nearfield response with a gated Free field response using Trace arithmetic in REW. I've done this previously and it worked fine but for a while now I have unexpected behaviour shown below. I'm merging the NF red response as B to the FFblue response as A at 300Hz. The resulting green line is gated the same as the FF response when I'd expect it to match the red response down to 20Hz. If I increase the time window the green curve just drops off quickly.
What's happening here and has something changed over the last few months?
thanks in advance
thanks in advance
I think I've solved it, the merging frequency is too close to the frequency at which I'm starting the sweep which is 100Hz in the case of the FF measurement. If I merge around 400 I get the behaviour I expect.
