Hi.
I have a Revox B226 with the usual problem.
A broken tray guide rail/
To cap it all, my spare player, a B126, has a crackedone as well.
Anyone know where I can get a replacement, either in the UK or Europe ??
Kevin
Kevin
If you are referring to cast metal guide for top and lateral rollers, no they are not available, except from scraped units which would serve as donors.
Yes, that's the part I require.
I had heard that someone was manufacturing replacements.
Kevin
I've always had good luck piecing them back together by using epoxy plus pins epoxied into grooves accross the breaks, then grinding smooth the guide tracks. Pretty much the only choice.
Is the die cast frame broken or twisted?
Unfortunately, it's both broken and twisted !!
So I think a replacement is required.
Kevin
- Digital Source
- Revox B126 / B226 = The Usual Problem!!
